BIM applications sets
2 REPLIES 2
Alfredo_Medina
280 Views, 2 Replies
Is Autodesk the only firm offering a set of BIM solutions, such as the Architecture, Structure, and MEP set, or is there any other company offering an equivalent set? I know that for architecture there is Bentley Architecture, Graphisoft's ArchiCAD, and Nemetschek's Allplan; for structures there is Tekla. But do these companies offer BIM solutions in the other disciplines? I did some research in the other companies' websites but it is not clear to me yet.
Alfredo Medina
info@planta1.com
2 REPLIES 2
rosskirby
in reply to: Alfredo_Medina
Graphisoft also has an extension to ArchiCAD for MEP, and I believe the structural is a part of the primary program. So to answer your question, yes, Autodesk appears to be the only vendor offering stand-alone programs for each discipline.
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
Thanks for your input. So it seems that Autodesk has an advantage in the market by having the only set of 3 BIM solutions sharing the same platform. I see that other companies seem to have separate products but they don't convey the idea of being a set of applications sharing the same base; they don't even have the same name. On the other side, The Revit A., Revit S., and Revit MEP set looks like a very attractive choice for a group of professionals who want to work together using the same platform.
Last night I was watching one of the AU lectures from Subscription Center. It was the "Collaborating across the disciplines.." class with David Cohn. I thought it was an excellent presentation, and I was very impressed to see how the 3 Revit solutions work together. There is still work to do, but the platform is solid and the future is very promising for this set of tools.
Alfredo Medina
info@planta1.com
