Beveled Countertops
5 REPLIES 5
BigPicture045
948 Views, 5 Replies
Beveled Countertops
I model countertops with floors. I would like to have a bevel around the edge of the countertop. As you can see in the image, the countertop I am modeling has a slight C-shaped bevel.
5 REPLIES 5
RDAOU
in reply to: BigPicture045
@BigPicture045
What is the question? how to model the beveled edge?
Edit the family >> create a void sweep >> in 3D pick the edges of the countertop >> finish sketch >> use cut geometry
BigPicture045
in reply to: RDAOU
How do you edit the family, it is a floor.
Then model in place and create a void sweep using the same method, cut geometry the floor with the void then finish the model in place.
RDAOU
@BigPicture045
That is an interesting way to model furniture and countertops! and so shall the swept void be too ... in-place.
Consistency is good...but you should consider modeling such elements as families instead
BigPicture045
in reply to: RDAOU
I was able to put a bevel on my [Floor Element] countertops by simply using  1 Model In-Place Void Sweep. Thanks for the help.
Forma Design Contest
