I am trying to create a new pattern for a bespoke brick, see attached:
brick: 218x65mm
vertical joint: 10.18mm
horizontal joint: 10mm
Help appreciated.
Solved by Pattycake_Kyle. Go to Solution.
Solved by David_W_Koch. Go to Solution.
Here you go: https://pattycake.io/pat/YlyAYAk5XbM
Just click download at the top. It's made with one of our calculators, so you can adjust the spacing and everything then redownload if you need to adjust for whatever reason.
Cheers.
Woops, hadn't refreshed and didn't see your reply. Sorry.
You solved the upload correctly --- I learned this too from user @pendean ... ""pat" is the Windows screensaver file extension too, and can be malicious if desired to be so: most of us simply ZIP when sharing them around here."
Why does the web generator create a pattern with 8 elements, doubling its complexity compared with David's ability to create the same fill arrangement with four?
HatchKit also manages with four within your Revit project - no web access required :
; Written by HatchKit Team Edition
; HatchKit Team Edition (c)1990-2019 Cadro Pty Ltd
; www.hatchkit.com.au/
;%VERSION=3.0
;%UNITS=MM
*Brick218x65mm
;%TYPE=MODEL
0,0,65,114.09,-75,218,-10.18
0,0,0,114.09,-75,218,-10.18
90,218,0,75,-114.09,65,-85
90,0,0,75,-114.09,65,-85
hth,
Hugh
hth,
Hufgh Adamson.
