Beams Showing As Thin Line
6 REPLIES 6
11128 Views, 6 Replies
Attached is a cross sectional view. As you can see the `I` beams are showing going in/out of the page but the ones going horizontally only show as a single line ( on the beams centre line ).  Is there a reason for this?  Is there a setting I can alter to get the full beam profile to be seen?
Darren
6 REPLIES 6
dzanta
double check the level of detail for the view...it may be set to coarse...set it to medium or fine and the beams should show properly.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
in reply to: dzanta
Thanks for the reply, it isn't that idea.  What I have found is that the beam of the top floor is thin lined and the others are thick.  No beam along the horizontal is cut in the sectional view so I'm a bit confused as to the different thickness especially as they are the same beam type.
dzanta
is there a view template override?
is there an element graphic override?
can you copy/paste the beams to a new project file to see if it looks the same?
is the Thin Line command turned on?
What is the scale of the section view?...sometimes having Thin Lines command off makes the view look strange
Can you make the screenshot larger and zoom in closer to the problem area?
s0171531
in reply to: dzanta
For me that worked! Had my beams as filled lines instead of seing the volumes, thank you!
kristina.starr
in reply to: dzanta
Thank you for your response, it helped me
Forma Design Contest
Technology Administrators
