Beam system
1 REPLY 1
183 Views, 1 Reply
Beam system
Hi Community! I create Beam System. but i can not make 4 boundary (red line in attached image) beamsystem1 copy.jpgbeam like attached image . How can i do? Thank you!beamsystem2.jpg
1 REPLY 1
ennujozlagam
hi, if you have difficulties creating boundary in plan view try to go 3D View > structure > beam system > pick support > pick your beam four corners or you can pick both end lines and add lines between the two lines. If you need to make a beam system you can also pick  the wall. hope it helps. thanks
Please see attached.
Forma Design Contest
Technology Administrators
