hi, if you have difficulties creating boundary in plan view try to go 3D View > structure > beam system > pick support > pick your beam four corners or you can pick both end lines and add lines between the two lines. If you need to make a beam system you can also pick the wall. hope it helps. thanks
Please see attached.
