Awning for deck
Awning for deck
AbdenourX8E3K
Awning for deck
AbdenourX8E3K
Hi Revit Savvy's!
I wonder what's the cleanest way to model this awning/pergola, curtain wall maybe?!
Please let me know if you have a better approach
EATREVITPOOPCAD
I would just do Model in Place and select specific types (Beam, Lights, Generic Model  etc...) and you can add parameters as required... But if the client is paying a million dollars for this, you can do something a lot more elaborate but I don't see why they would... Curious what others will say honestly, good post sir!
The definition of insanity is doing the same thing over and over again and expecting different results
RDAOU
@AbdenourX8E3K
Both of the following are easy/easiest/same easiness:
  1. Roof / Sloped Glazing
  2. Beam System
You should also be able to pull it off with
  • a Pattern Based Family on a Divided surface of a mass (Slightly more work but would save you lots of time later)
  • An array in a Generic Model
  • An adaptive family (incase you want to go crazy and randomize sizes, shapes and angles
mhiserZFHXS
I would definitely say a curtain system, and create the custom panels and "mullions" needed. That way you could easily modify it if needed.
syman2000
I would create curtainwall and use the mullion to divide them. See attached
