Revit freeze while exporting DWG files
m.shaheenQVUGH
m.shaheenQVUGH
Hi all, we have a specific section view in the project. every time, try to export it in DWG format the Revit freeze at 33% and then stays forever.
I attached here the journal file if anyone can help and tell me where is the problem.
syman2000
In the section, does it have custom crop boundaries? Try turning off CAD links and see if that helps improve the issue. If that didn't solve it, try hotfix and see if that help solved your issue.
ennujozlagam
have you try to install latest updates from autodesk and see if helps. thanks
