German windows family: sill properties
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
semi
330 Aufrufe, 3 Antworten
in the german content folder under category "Windows" you can find all sorts of nice window families.
There is just one setting that bothers me: the position of the window sill.
How can I make the stone sill appear underneath the window mullion instead of in front of it? I can't find the parameter that changes this:
3 ANTWORTEN 3
Nachricht 2 von 4
RDAOU
als Antwort auf: semi
@semi
It is modeled that way...There are no parameters to extend it below the frame/sub-frame. That is more or less the standard way of executing window sills for commercial windows all over Germany (usually folds up against the window frame though)
If you want to extend it below the window you would need to edit the frame sweep and the sill extrusion and re-constrain them.
Nachricht 3 von 4
Another approach would be to make the Window's sill invisible (the parameter may already be there) and model your stone sill in the project using Wall Sweeps or some other method.  I mean, I don't know any Window Manufacturers that offer a stone sill option, so this would be an appropriate approach since that stone sill would be done by a different contractor than the Window installer.
Nachricht 4 von 4
semi
als Antwort auf: barthbradley
@barthbradley that actually makes a lot of sense
I guess I've always been used to an integrated stone sill in window families
