I am having an issue in creating an awning family with angled louvers inside a frame. It works as expected, except if I set a Type Parameter for the angle of the louver to 90 degrees - the louver will set to the angle intended, but the next time I change the angle, Revit says the constraints are not satisfied. Can you help me understand this angle locking issue?
Solved by barthbradley. Go to Solution.
Weird. I cannot open file in either 2018 or 2019, but I can see thumbnail. Must be "Hump Day". Going downhill.
Okay, got over the hump and was able to open it. Nest the louver into the family, hosting it to a Ref. Line which is labeled with an angle parameter.
So does the louver need to be a Generic Line-Based family?
Should the host Ref. Line be parallel to the rotation axis (louver rotates around host line) or perpendicular to it (louver rotates with host line)?
Hard to explain in writing what to do, and I can't take the time to build it to show you. But, I'm going to offer you something of greater value. Read and follow the instructions in the link below, and I guarantee you will take away from it the best foundational knowledge to build any family of this type.
Give a man a fish and you feed him for a day. Teach a man to fish and you feed him for a lifetime.
http://planta1.com/blog/rotating-a-revit-model-family-in-3-different-axes-by-reference-lines/
p.s. you don't need 3 levels of nesting for yours, but the basic principals still apply.
