Automatic openings
Automatic openings
XXalessio.amodioXX
Message 1 of 21
Automatic openings
XXalessio.amodioXX
Hi all,
I believe this threadh was faced many times.
By your experience, what is the best way to cope with the void issue of piping and HVAC system thtrought wall/floor?
Do you use any plug in/dynamo script?
Replies (20)
Message 2 of 21
PavelAnd
Hello @XXalessio.amodioXX . Look for this tool. Video about it.
Best regards, Pavel Plotitsyn.
Message 3 of 21
XXalessio.amodioXX
There is no free version for revit 2020
Message 4 of 21
PavelAnd
Oh, i am using R2019. Look this link.
"Cut Opening Free is a free app. The activation code is sent via email."
Message 5 of 21
XXalessio.amodioXX
Very nice free tool.
Message 6 of 21
XXalessio.amodioXX
Hi, PavelAnd
tool very nice but gives me error for structural beam.
Is it because of free version?
Message 7 of 21
PavelAnd
Hi @XXalessio.amodioXX. I didn’t have such a problem... Upload your file, please
Message 8 of 21
XXalessio.amodioXX
HI,
Simple project using revit families.
Message 9 of 21
PavelAnd
Unfortunately, I can’t check this file today because I have Revit 2019 installed. And I can’t reproduce your error. Try changing the beam profile, moving the pipe, connecting the file with the pipes as a link... Maybe this will help to understand why this error occurs.
Message 10 of 21
XXalessio.amodioXX
With walls and floors is working properly.
With structural beams/columns I receive a message telling me that the process is not supported.
Message 11 of 21
XXalessio.amodioXX
Message 12 of 21
RDAOU
@XXalessio.amodioXX
You can try to reverse the select in the interference check (pipe then beam); however; As per the product description, it only supports wall, floor, ceilings and roofs...Same is stated in the popup prompt message (see below) ...but again how can one expect a complete solution packaged all for free 🙂
Tools4BIM most probably do have an add in  which can host openings in Structural framing and columns but I guess that would be the paid version of this one
Message 13 of 21
Amodio.Alessio
I am just wondering if the troubles comes from Revit or from the free version. Because this pop up .
Message 14 of 21
RDAOU
@Amodio.Alessio
The issue is definitely not from Revit...I can cut openings in structural framing and columns using Dynamo; hence, no issue in the Revit element/category.
A wild guess would be "the free version" usually those come with limited options... There is a trial download for the paid version "Cut Openings 2020" you can download and try it out to verify 🙂 I personally prefer to stick to Dynamo
NOTE: I am guessing that "Cut Openings Free" and the trial version of "Cut Openings 2020" are two different things
Message 15 of 21
Amodio.Alessio
The free version does not allow to solve Structural Beam/Columns opening
Message 16 of 21
XXalessio.amodioXX
I am sorry.
I am messing around with my personal and commercial account.
By the way, the free version does not allow to solve structural column/beams connection.
Message 17 of 21
RDAOU
ok 😄 and if it doesn't why are you marking everything as solutions lol
Message 18 of 21
XXalessio.amodioXX
I like green color 😉
Message 19 of 21
RDAOU
You are fishy lol
Message 20 of 21
pellemeholm
Hi  XXalessio.amodioXX,
you can test the new plug-in conVoid ( https://www.conclass.tech/convoid ), which converts openings and tracks changes based on all kinds of IFC and/or Revit-Elements. It is an advanced openBIM workflow for converting and coordinating all types of voids between architects, structural engineers, and mep-engineers.
Let me know if you need more information.
Kind Regards
Pelle
