Merging cells in schedules
Is there a way of merging these cells to create a single one?
RDAOU
@Anonymous
Depending on the version you are using... you can use the Combine Parameters under Fields tab
I'm using Revit 2019.
I wanted to merge all the cells "Terreno" in a single cell.
Like this user tried to do: https://forums.autodesk.com/t5/revit-architecture-forum/merge-cells-in-a-column-when-the-cell-values...
RDAOU
@Anonymous
No then I misunderstood...Merging is only possible horizontally
Your only option is to use sorting and grouping...sort by comment then hide the comments column (See below)
