Automatic Ceiling tool not working
tstewart
Message 1 of 16
tstewart
Automatic Ceiling tool not working in 2023. How to draw SAT ceilings automatically?
Replies (15)
Message 2 of 16
jay_colc
Can you confirm your Walls are Room Bounding in the Properties Palette
and the Ceiling Height is lower than the Wall Height
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 16
hmunsell
to piggy-back on @jay_colc .... are you sure your ceiling is Below the top of your walls. if you place your ceiling at the same elevation as the top of the wall, it will go over the top.
Howard Munsell
Message 4 of 16
hmunsell
also, depending on what version your running, make sure your walls are not slanted.
Howard Munsell
Message 5 of 16
tstewart
Wall hts are 14' and Ceil. hts. are 9'. All walls were drawn in plan and show on the Reflected Ceiling plan.
Message 6 of 16
tstewart
Revit 2023
Message 7 of 16
jay_colc
If you select a Wall is there a Tick where is states Room Bounding in the Properties Palette?
Jay Colcombe
Message 8 of 16
hmunsell
are the walls set to Vertical? if set to tapered or slanted you cannot place an automatic ceiling.
Howard Munsell
Message 9 of 16
tstewart
The walls are vertical and there is no "tick" where it states "Room Bounding."
Message 10 of 16
jay_colc
This is the issue, if the Wall are not bounding they cannot automatically define the boundary for the ceiling
Jay Colcombe
Message 11 of 16
tstewart
Bounding is checked in Properties, so should it be unchecked?
Message 12 of 16
jay_colc
The Walls create the perimeter for the ceiling so the Walls need to be room bounding “Ticked” in the properties palette for the walls.
Room bounding for the ceiling means the ceiling is used as the top of the room (box) rather than the floor above.
Jay Colcombe
Message 13 of 16
hmunsell
would you be able to upload the file for us to look at?
Howard Munsell
Message 14 of 16
tstewart
FYI
Message 15 of 16
jay_colc
Nothing attached?
Jay Colcombe
Message 16 of 16
jay_colc
For Clarity,
4 Walls all room bounding above the height of the Ceiling level
Ceiling Automatically detects bounding elements and will be created
If there is no full boundary no Ceiling cannot be automatically created
This would require manually sketching the boundary of the ceiling
Jay Colcombe
