Sheet Number Order Issue
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
Kev_D
421 Aufrufe, 5 Antworten
We have an issue where some of our sheets have jumped into a different location in numerical order. All parameters, filters and project browser settings are correct.
The sheet schedule also shows the same order
It was ok before a few tasks were completed with pyRevit involved:
  • Reloading Links
  • Printing sheets to PDF
  • Exporting to CAD
I can't replicate it. Could it be an API bug? The user said it happened once before but I have never seen it happen.
5 ANTWORTEN 5
Nachricht 2 von 6
jay_colcombe
als Antwort auf: Kev_D
Do you use pyRevit?
pyRevit orders sheets using a different parameter and add Unicode character to sheet number to sort them the same way in the browser.
Jay Colcombe
Autodesk Certified Instructor
Nachricht 3 von 6
jay_colcombe
If you do use pyRevit this thread may help?
https://forums.autodesk.com/t5/revit-architecture-forum/sheet-order-problem-after-printing-with-pyre...
Jay Colcombe
Nachricht 4 von 6
syman2000
Since you are using pyrevit, just use reorder sheets
Nachricht 5 von 6
Kev_D
Thanks, I will delve into this tool more and look at the other link.
Nachricht 6 von 6
Kev_D
Discovered by a colleague, the sheets contained hidden unicode, so it was obviously from pyRevit like you both mentioned. He managed to push the sheet list to ChatGPT to remove unicode characters and push it back into a script to clean Revit.
