Hello Everybody
Can I use NVIDIA QUADRO T1200 - 4GB with Autodesk Revit 2024?
Kind Regards
Solved by jrossouw-za. Go to Solution.
yes you can but , I am using RTX 4000 ,but i am not happy with that. in large project it is hard to working but with huge one it is terrible and you should make the project to suitable pieces and you can see the different :
Yes, but as @azad.Nanva says - it's not exactly fast. So if you have a choice of videocard, I would recommend Nvidia GeForce RTX.
Hi @jrossouw-za
Thanks a lot for posting your question to the forums! Have the solutions suggested by @azad.Nanva @vitorbortoncello @Simon_Weel helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Yes you can use it. Will it be pleasant to use? No.
Hello Everybody
Thanks for all the replies. I have quote my customer on a Refurbished Dell Precision 3530 -I7 8TH GEN / 32GB RAM / 1TB SSD / NVIDIA QUADRO T1200- 4 GB / 15.6" LCD / WIN 10. As you all know new Dell Precision are very expensive. Waiting for my customer to accept quote.
Thanks\Kind Regards
