Autodesk Revit 2020 Constraints Properties Issue on Wall and Level
LanggamanXavierMassed
Hello Everyone, the top constraint does not seem followed in the modelling area, I had a hard time adjusting this wall height with the properties palette and it's not changing. I set it to "up to level: 2ND FLOOR LINE" and it's still not hitting it.
I tried to do a separate wall sample beside the model to check, i did the setting at the properties palette and it was good, but does not work with particular wall beside a retaining wall with a column, how is this happening? Thank you so much!
joe_keogh
Hi @LanggamanXavierMassed
Can you try selecting the wall and from the Modify Tab, click Detach Top/Base.  Then from the Options Bar, click Detach All.
Joe Keogh
Director | Design Technology + Innovation
www.viewlistic.com.au
Well, the top of the wall is exactly at the 2nd floor level as the properties panel indicates.  I think you mean to say you want it to attach to the sloped roof above.  If so, select the wall and use Attached Top/Base button from the ribbon, then select the roof.
Oh Thank you Sir! this is very helpful for a beginner, you are awesome!
