Autodesk Revit Match Properties
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
LanggamanXavierMassed
3071 Aufrufe, 2 Antworten
Hello everyone! I tried to match one column with the other column, I used MA command to make them the same in length and it's not working. how do cases like this happen? thank you very much
2 ANTWORTEN 2
Nachricht 2 von 3
joe_keogh
als Antwort auf: LanggamanXavierMassed
Hi @LanggamanXavierMassed
Match Properties (MA) matches Type Properties.  Not Instance properties.
For instance properties, you would need to select all the columns you want to extend to the same height and enter the distance into the Instance Properties.
Joe Keogh
Director | Design Technology + Innovation
www.viewlistic.com.au
Nachricht 3 von 3
it will now work with the height, it will only work with material and size. thanks
