第 1 条消息(共 4 条)
Hello Everyone, the top constraint does not seem followed in the modelling area, I had a hard time adjusting this wall height with the properties palette and it's not changing. I set it to "up to level: 2ND FLOOR LINE" and it's still not hitting it.
I tried to do a separate wall sample beside the model to check, i did the setting at the properties palette and it was good, but does not work with particular wall beside a retaining wall with a column, how is this happening? Thank you so much!
已解决! 转到解答。
