Autodesk Desktop App wont open, cant uninstall
7 REPLIES 7
Message 1 of 8
a_paynter
256 Views, 7 Replies
Hi there,
not a Revit post but i couldnt find anywhere else to post this.
Basically the Autodesk Desktop App has suddenly stopped working. It's no big deal in and of itself, Revit, Autocad and 3DS Max are all still working just fine, but it is curious.
The message i get when i try to open it is "the file or directory is corrupted and unreadable". I've run SFC and CHKDSK scans, everything on the drive appears to be in working order.
When i try to uninstall the Autodesk Desktop App, Windows tells me that the "removeAdAppMgr.exe" file cant be found anymore.
How can i safely remove the carcass of this app from my computer and then reinstall it?
Thank you in advance
7 REPLIES 7
Message 2 of 8
Lachlan-JWP
in reply to: a_paynter
Have you tried using the Autodesk Uninstall tool?
Message 3 of 8
Version 8.3.0.71 ?
Message 4 of 8
ennujozlagam
https://forums.autodesk.com/t5/autodesk-desktop-app/autodesk-desktop-app-wont-uninstall/td-p/6420947
Message 5 of 8
a_paynter
in reply to: Lachlan-JWP
i have not but i will now, thanks for the tip
Message 6 of 8
a_paynter
in reply to: barthbradley
no i think it was the previous version. I had noticed that the Autodesk Desktop App on my office machine had updated and looked a little different to the one on my home machine - new logo etc.
I only noticed that because for a short while there leading up to the corruption message, the ADA was always open and ready to go when i booted up my home machine, even before the desktop icons had loaded themselves. And now suddenly, its stopped working all together
Message 7 of 8
a_paynter
in reply to: ennujozlagam
thank you for the link, but im not seeing an instance of the ADA running in the system tray
when i navigate to the services in the task manager, the associated services that i apparently need to stop have already been stopped
the problem im having here is that the program itself is somehow damaged, so much so that the files associated with removing it have also been damaged
i tried downloading the app from AD and installing over the old install, but it didnt change anything
Message 8 of 8
johnmalone0
Has anyone found a solution to this? I am getting the same message when trying to uninstall this?Autodesk Problem.jpg
Forma Design Contest
Technology Administrators
