AutoCad 3D solar analysis to Revit
Message 1 of 12
I insert the autocad file in revit following the steps from a solution i saw in the forum. But when I try to solar analysis the building , revit doesn't let me choose the interior or exterior walls . The only think that Revit lets me to do is to just 3D view the building. Is there any possible solution to my problem ?
Replies (11)
Message 2 of 12
What steps?
Message 3 of 12
Viveka_CD
@Anonymous
Welcome to the community!:)
Can you share the file and a screencast of what you are experiencing?
That will help us to help you better.
Best Regards,
Message 4 of 12
Sounds like you are trying to do what is described at 7:50/10:29 on this video:
https://www.youtube.com/watch?v=HKzXY9CZJWo
Message 5 of 12
I try to process this dwg file but when i import it in revit it doesn't allow me to do anything. I want to solar analysis the exterior walls and when i try to choose them nothing happens. Is there a solution in order to process this dwg file ?
Message 6 of 12
Model it in Revit or Model it in AutoCAD Architectural with Architectural Elements.
Message 7 of 12
So if i model it in autocad artchtectural an d then import it in revit i will be able to process it and do my solar analysis ?
Message 8 of 12
No. You need to export from Autocad architecture to IFC then open or link the IFC in Revit.
Message 9 of 12
Ok i exported the autocad in IFC. Now i just link the IFC in Revit like a new drawing and i can process it ?
Message 10 of 12
Did you specify the correct IFC export options?
https://knowledge.autodesk.com/support/autocad-architecture/learn-explore/caas/CloudHelp/cloudhelp/2...
Message 11 of 12
Yeah I converted right. Everything worked. Thank you very much
Message 12 of 12
ce23e009
Community Visitor
Community Visitor
i m also getting same problem while importing 3 modelsfrom solidwork to revit via autodesk but not able to select the surface to solar analysis can any one please me out ?
