Are you creating the floor in link files itself or in the main drawing where your link file is a link? Have you tried to audit both files before linking them. Thanks
I was creating the floor in the main file where i linked the models. Is audit meant for worksharing? I have not using work sharing for this. I am doing it locally myself.
Audit function periodically to maintain the health of a Revit model, when preparing to upgrade the software, or as needed to locate and correct issues. The Audit function scans, detects, and fixes corrupt elements in the model. It does not provide feedback on which elements are fixed
can you untick your use hardware acceleration from options > hardware and see if helps. thanks
unload your link file then create your floor, if you managed to create your floor without issues then reload again your linked file it could be linked files has the issues. thanks
@Anonymous can you post a copy of the journal file after Revit crashes, for review?
REVIT: LOCATION OF JOURNAL FILES
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/Location-of-journal-files.html
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Attached with the Journal files for 25th and 26th June 2019.
Thanks.
Yes, the problem only appears when the user starts linking revit files. Without linked files, everything is just fine.
