1. General stability for Revit
Revit is still heavily CPU‑bound in many tasks (single‑thread performance, memory, storage). On paper, that Z13 looks very strong for Revit:
- CPU: Ryzen AI MAX+ 395 (likely high clocks + decent single‑thread performance).
- RAM: 128 GB is excellent for:
- Large central models and many linked RVTs
- Heavy point clouds
- Running Revit + Enscape/Twinmotion + other apps simultaneously
- Storage (assuming fast NVMe, as in older Flow models): good for load/save/sync times.
From what we know from:
- Prior ROG Flow and ROG Zephyrus generations.
- Older Ryzen + Radeon laptops running Revit.
You can expect:
- Revit itself to be stable, as long as:
- You use current GPU drivers (not the factory ones, and not ancient).
- You use a supported Revit version (2021+ ideally).
- You keep Windows + BIOS up to date.
I would not expect systemic crashes just because of the ASUS hardware itself. The usual Revit crashes (family bugs, bad add‑ins, network hiccups, corrupt elements) will still exist, but they’re not specific to that machine.
2. Viewport performance and GPU specifics
Revit’s graphics pipeline (especially newer versions with “Advanced Graphics”) does leverage the GPU more than it used to, but it’s still not a game engine.
The Radeon 8060S isn’t a known SKU yet in my knowledge window, but if it follows the pattern of mobile Radeons in gaming laptops:
- 3D navigation in Revit should be smooth for:
- Medium to fairly large architectural/MEP/structural models.
- Consistent 60 FPS in shaded/consistent colors views at FHD/QHD resolutions.
- Performance can dip for:
- Very heavy models with many links and lots of detail items.
- Realistic mode with high‑res textures and lots of transparency.
Driver behavior (historical AMD vs Revit):
- Autodesk has historically been more “NVIDIA‑friendly” in terms of tested/workstation drivers, but current AMD Radeon drivers are generally fine for Revit.
- Occasional issues you may or may not hit (based on older Radeon setups):
- Minor flickering in the view when orbiting in realistic mode.
- Ghosted/vanishing elements when zooming very fast in some views.
- Occasional crash on view regeneration if the driver is buggy.
Workarounds that usually help:
- Turn off some advanced graphics options:
- Disable hardware anti‑aliasing or reduce level.
- Turn off “smooth lines with anti‑aliasing”.
- Keep an LTS (long‑term support) driver version once you find a stable one.
3. External monitors
ROG Flow devices are designed to drive external displays (and even eGPUs on some models), so:
- Running Revit on dual 27"/32" QHD or a single 4K should be fine.
- Watch out for:
- Mixed DPI scaling (laptop screen at 150–200%, external monitor at 100%) — Revit’s UI can get slightly fuzzy or mis-sized.
- USB‑C/hub docks: If you use a cheap hub with DisplayLink, you can get laggier viewports. Prefer direct HDMI/USB‑C alt‑mode, or a quality dock that passes through the GPU signal rather than virtualizing it.
In practice, on similar Asus devices:
- 1×4K or 2×QHD external monitors with Revit is totally usable.
- If you see lag when dragging windows or orbiting models, try plugging the main monitor directly into the laptop instead of through a dock.
4. Enscape and Twinmotion on this hardware
Here’s where the GPU choice matters more. Both Enscape and Twinmotion lean heavily on GPU.
Enscape:
- Prefers NVIDIA historically, but runs on modern AMD GPUs as well.
- With something in the class of an “8060S”, you can expect:
- Good performance at 1080p / 1440p, medium‑high quality.
- Real‑time walkthroughs, VR maybe at reduced quality.
- Potential AMD‑specific issues (based on prior gens):
- Occasional material quirks or lighting artefacts on specific driver versions.
- Rare driver timeouts on very heavy scenes if VRAM is stressed.
Twinmotion:
- Built on Unreal Engine, quite GPU‑hungry.
- On mobile AMD GPUs, you’ll typically get:
- Good experience for small/medium scenes.
- For huge urban/landscape scenes, you may want to:
- Reduce shadows quality.
- Turn down reflections and foliage density.
- Stability-wise, Twinmotion on AMD is generally fine, but it’s more sensitive to driver versions than Revit.
General advice:
- Update to the latest stable Radeon driver when you first install Enscape/Twinmotion.
- If something breaks after a driver update, roll back one or two versions (keep the installer of the last known good driver).
5. Things to watch with the ASUS ROG Flow form factor
The Z13 is a tablet‑style, thin and light device. That’s great for portability, less ideal for long, sustained loads in viz apps.
Watch out for:
Thermals and throttling
- Under long Enscape/Twinmotion sessions or long renders, CPU/GPU may:
- Heat up and reduce frequency (throttle).
- Suddenly drop FPS after some minutes even if it was smooth at the start.
- Mitigations:
- Use Performance/Turbo mode when plugged in.
- Raise the rear/put on a stand or cooling pad to help airflow.
- Avoid blocking vents with desk clutter.
Power modes
- Make sure Windows and Armoury Crate (or whatever ASUS uses) are set to a high‑performance profile when you’re on Revit/Enscape/Twinmotion.
- On battery, expect sharp drops in performance — Revit will run, but Enscape/Twinmotion will feel “choked”.
Pen/touch
- Revit is okay with pen input for markups, but not optimized for full modeling by pen. No stability issues expected; it’s just a comfort thing.
6. Risk/benefit vs a more “traditional” Revit laptop
For pure Revit + Enscape/Twinmotion work, the Z13‑class device trades:
- Pros:
- Extremely portable.
- Powerful CPU + plenty of RAM.
- Clean external monitor setup for office + mobile for site/client.
- Cons:
- Less thermal headroom vs a thicker workstation laptop.
- AMD Radeon instead of NVIDIA RTX (which is what most viz people + Autodesk benchmarks target).
- Possibly more fan noise under load.
If you’re very Enscape/Twinmotion‑heavy and buy one machine for everything, a classic NVIDIA RTX‑equipped 15–16" workstation-ish laptop still tends to be the “safe default”. But the Z13 should absolutely be capable for Revit and moderate viz work.
7. Practical recommendations if you go with it
Once you get it, to maximize Revit stability and performance:
- Immediately update:
- Windows.
- GPU drivers from AMD.
- BIOS/firmware from ASUS.
- In Revit:
- Use a supported, recent version.
- Enable “Use hardware acceleration”.
- If you see weirdness, try:
- Disabling “smooth lines with anti‑aliasing”.
- Changing anti‑aliasing mode / quality.
- For Enscape/Twinmotion:
- Keep a copy of the GPU driver installer that works well.
- Do a quick stress test on a big model and watch temps and clocks.
