Associate Type Parameter Button Missing In Nested Families
EATREVITPOOPCAD
Message 1 of 10
EATREVITPOOPCAD
Using Revit 2023, and this is nested families type parameters. All the associate parameter buttons are missing. The parameters are not driven by formulas. I've seen this a few times, not sure what causes it. Any ideas?
The definition of insanity is doing the same thing over and over again and expecting different results
Replies (9)
Message 2 of 10
Alfredo_Medina
That button is available for instance parameters in the nested family, not type parameters.
Message 3 of 10
EATREVITPOOPCAD
That is what I found on many forum posts, however, this is not true. See the example below, this is a door family with a nested frame family. As you see, I have a few type parameters associated.
Message 4 of 10
syman2000
If the nested family is set to shared, then those parameter will not appear unless you set them as instance parameter.
Message 5 of 10
Alfredo_Medina
It works with type parameters for some categories, such as windows, profiles, and doors as you mentioned. But for general purposes, if you want to associate parameters from a nested family with parameters in a host, use instance parameters in the nested family.
Message 6 of 10
EATREVITPOOPCAD
@syman2000 The nested family in both snippets i showed is shared.
@Alfredo_Medina That is insane if it works for some categories but not others o_O Can't image why it was intentionally made this inconsistent
@EATREVITPOOPCAD - this post has been edited due to Community Rules & Etiquette violation
Message 7 of 10
Alfredo_Medina
Well, that's the way it is. I am just telling you what I've seen. Life is not perfect.
By the way, I don't see the point of the video that you posted
Message 8 of 10
EATREVITPOOPCAD
The GIF is an allusion to a theory that life is not perfect because two different developer teams were partaking in recreational activities which made them forget to communicate with each other.
I could be wrong though, maybe there is a good reason that justifies this... It just seems like sloppy seconds.
I do appreciate the response though, would've never guessed 🙂 Drove me crazy for a bit, glad I finally looked in to it
Message 9 of 10
syman2000
Yes nested shared family type parameter cannot tie them to current family parameter unless you set the nested family parameter as instance parameter. There is a reason why they did this. Since nested shared family will appear in the project browsers, it would be counter intuitive if the type family is tied to another family.
Message 10 of 10
EATREVITPOOPCAD
@syman2000 ahhhh, ok that makes sense. Thank you!
