Assemblies, add to assembly
RJU_Vinitex
Message 1 of 1
RJU_Vinitex
Why, in their infinite wisdom, did Autodesk decide not to allow drag-select elements to be added to an assembly???
I have to place multiple views of over 40 assemblies onto sheets, yet I need to manually click dozens of separate elements from each assembly to be added to that assembly otherwise they don't show up on sheet...
The assemblyThe assembly...in Edit mode...in Edit mode...manual Adding 1 by 1...manual Adding 1 by 1What appears on sheet.What appears on sheet.
Can't I make those shared families visible on the sheets without needing to add them all 1 at a time? Why are shared components not automatically added like non-shared ones?
Is there a workaround, add-in or Dynamo script for this? Shared families have to remain shared though.
Replies (0)
