Assemble create view unhide top elements
qixing.chenNYA88
Message 1 of 12
qixing.chenNYA88
I create an assembly and used create view. However, the top elements are hided in the view. Could anyone help with this?
Very appreciate your help!
Replies (11)
Message 2 of 12
You mean it's cut off in Elevation Top View?
Message 3 of 12
qixing.chenNYA88
Yes, I think so.
Message 4 of 12
Was the top included in the Assembly? If not, then Edit and Add it.
BTW: This is what I mean by "Top" View:
Message 5 of 12
qixing.chenNYA88
I think I misunderstand what you said. I want to created a 3D view of the assembly however the top elements are not visible from the view. Do you know what setting I should change? The first picture has covers and they disappear in the 3D view.
Message 6 of 12
Were you including the cover when creating the assembly?  No.  Just edit the assembly and add it in.
Message 7 of 12
qixing.chenNYA88
Yes, the top covers are in the assembly.
Message 8 of 12
How would you know? In which assembly views do you see it?
Message 9 of 12
What's the name of the Assembly View you are in?
Message 10 of 12
qixing.chenNYA88
It's the 3D view. I found out the solution and it worked. The cover is a nested family in the frame and I recreated it in the Frame's family.
Message 11 of 12
The nested family is shared.  You could keep it as is, just add it to the assembly by using TAB to select it.
Message 12 of 12
So basically, it's a Shared Family that is NOT added to the Assembly.  So, Add it then.
