Array with changing angle not working (array elements move away from the refrence line)
Hallo everyone,
Can some one please help me. i made a revolve element on the reference line and gave the angle parameter to control the slope.
Now i made an array on the same referencewithout array.PNGarray elemnst moved.PNG line but when i change angle, the arrayed elements move away from the reference line.
please check the pictures and also uploaded the family.
L.Maas
Arrays are often tricky.
You might try to create the array in a nested family. Then load it into the host and do the rotation of the nested family there.
Louis
Please mention Revit version, especially when uploading Revit files.
Thank you so much for response. it worked.
martijn_pater
@AnonymousUse a line-based nested family on the refplane.
