PRINTING ISSUES
11 ANTWORTEN 11
Nachricht 1 von 12
ngurearchitect
691 Aufrufe, 11 Antworten
PRINTING ISSUES
I have two issues here with regards to printing :
1.  Revit has completely refused to print for some reason.
2. My Microsoft to PDF print set up option does not provide enough choice of papers.
Any suggestions?
Tags (1)
Beschriftungen (1)
11 ANTWORTEN 11
Nachricht 2 von 12
ennujozlagam
als Antwort auf: ngurearchitect
you can try another printer driver like BULLZIP and see if you can print. thanks
Nachricht 3 von 12
ngurearchitect
als Antwort auf: ennujozlagam
 It still hasn't worked ..no matter which pdf printer I use once I click print its completely unresponsive and I don't know why ...
Nachricht 4 von 12
ngurearchitect
In fact the only option that works is batch file printing
Nachricht 5 von 12
ennujozlagam
have you try to install latest updates from autodesk, sometimes if fixes issue. another way is to check your OS windows by referring to this LINK or worse scenario is either to repair or  clean uninstall and reinstall your revit program and see if helps. thanks
Nachricht 6 von 12
ngurearchitect
yes I have the latest revit update 2020.2
Nachricht 7 von 12
ennujozlagam
you can refer to this article and see if helps. thanks
Nachricht 8 von 12
ngurearchitect
my problem doesn't seem to be listed.
Nachricht 9 von 12
ennujozlagam
if you choose microsoft print to pdf these are the only available papers sizes you can choose, my recommendation is to use another printer driver available in the internet for free. are you seeing this when you print to pdf? thanks
Nachricht 10 von 12
ngurearchitect
I am not using Microsoft print to PDF ...in fact my printer dialogue does not allow me to print after making all other changes once I click okay nothing happens.
Nachricht 11 von 12
ennujozlagam
what pdf printer driver you are using. thanks
Nachricht 12 von 12
ennujozlagam
the only way is do a clean uninstall  and reinstall again your revit program, it could be some files are corrupted. thanks
