Array with changing angle not working (array elements move away from the refrence line)
3 REPLIES 3
586 Views, 3 Replies
Hallo everyone,
Can some one please help me. i made a revolve element on the reference line and gave the angle parameter to control the slope.
Now i made an array on the same referencewithout array.PNGarray elemnst moved.PNG line but when i change angle, the arrayed elements move away from the reference line.
please check the pictures and also uploaded the family.
3 REPLIES 3
L.Maas
Arrays are often tricky.
You might try to create the array in a nested family. Then load it into the host and do the rotation of the nested family there.
Louis
Please mention Revit version, especially when uploading Revit files.
in reply to: L.Maas
Thank you so much for response. it worked.
martijn_pater
in reply to: L.Maas
@AnonymousUse a line-based nested family on the refplane.
Forma Design Contest
Technology Administrators
