Hallo everyone,
Can some one please help me. i made a revolve element on the reference line and gave the angle parameter to control the slope.
Now i made an array on the same reference line but when i change angle, the arrayed elements move away from the reference line.
please check the pictures and also uploaded the family.
Solved by martijn_pater. Go to Solution.
Solved by L.Maas. Go to Solution.
Arrays are often tricky.
You might try to create the array in a nested family. Then load it into the host and do the rotation of the nested family there.
Louis
Please mention Revit version, especially when uploading Revit files.
@AnonymousUse a line-based nested family on the refplane.
