array along path
array along path
tenak333
array along path
tenak333
Hello!
How can I array an element along path?
I understood that I need to create a spline and divide it in parts, and I managed to do that.
But I don't know what is the next step.
(I am working in Revit 2015.)
Thank you!
Mirko.Jurcevic
Array along the path is not possible in Revit.
You can only do linear and radial arrays in Revit.
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
段小文
I made some families in this area, which should be what you want, and the parameters are more complicated.
Mirko.Jurcevic
You can check this forum post with similar issue:
https://forums.autodesk.com/t5/revit-architecture-forum/path-array-in-revit/td-p/7371003
This is solution using Dynamo:
https://www.youtube.com/watch?v=i7QRdJ9Qwhs
This tutorial shows how to attach family to adaptive point to be able to place it or rotate into any direction in Revit:
https://www.engipedia.com/rotate-revit-family-into-any-direction/
Mirko Jurcevic
tenak333
Is there a work around?
Something with tools I mentioned in the first post?
Or with railing tool?
Mirko.Jurcevic
There is no native tool in Revit that will do that.
If the category does not bother you, yes, you can put your family into baluster family and set that baluster in railing family type.
Mirko Jurcevic
