Hi!
We have a problem with wall opening from Revit to IFC. Any ideas or a bug? Maybe @angel_velez know?
Revit 2020.
IFC 2x3 (Tried IFC4 as well, same result)
Using Revit IFC exporter 20.1.0.2
Attached is a sample file of our Revit model and IFC.
In Revit:
In IFC:
In Revit the opening is made by our Door-family. And it is a correct wall opening in our Revit model. But not when exported to IFC.
Gelöst! Gehe zur Lösung
Gelöst von JR_Bimlund. Gehe zur Lösung
FWIW: No problems here. You sure you are doing it right? Seems pretty straight-forward. I can't imagine what you did wrong.
Following….
Got help from the support. THe Door-portal family contained several wall openings. It was fine in Revit but not when export. So make sure Door-familys only contain one wall opening.
We are experiencing the same problem The door opening is correct in Revit (right image) but is not existing in the IFC (left side). I am attaching a Revit 2021 project with that door family, and the exported IFC.
I only see 1 opening cut in my family.
What is going on?
