Solved by Sahay_R. Go to Solution.
Solved by Viveka_CD. Go to Solution.
Solved by ToanDN. Go to Solution.
I see that you are visiting as a new member! Welcome to the Autodesk community!
Are you trying to design an element in particular? We could see if we have other ways of design it for you.
You can try using a spline edit points and use the divide tool to achieve the same results as an array would do.
See HERE for a similar discussion
More information about the Array tool in Revit
See HERE for a screencast to create a Revit path array using Dynamo
Looking forward to your reply update.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Try Railings. Place the objects to array as balusters.
Hello @Mohamed.E.Salem
Please let us know if further assistance is needed from the community on this post. We are happy to help wherever possible.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. Kudos welcome!
Viveka CD
