I'm having an issue opening a project file that was sent to me. The following error comes up when opening the project: "AREXRevitStart: REXExtension: DReinfWall Error".
I have tried clicking on multiple options but the Architecture of the project won't show on any of the views. It seems like it only shows some annotations, and callouts. Could you please help me locate where I can fix this issue? Or where to download what I'm missing?
Thank you in advance!
Thank you, I read it but as a solution it says "Install the third-party application on the machine which receives the message." But I cannot find where to download this.
Thank you,
Thank you,
The model should still show even if you don't have the extension installed. If not, it is a badly coded extension, which I doubt it because BIMWare appears to have a good reputation.
Set the view to Coordination discipline. Or share the file here so we can have a look.
