Cavity door OTB show door leaf not full frame size
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
wisedrawing
340 Aufrufe, 3 Antworten
anyone have an idea for Revit OTB cavity door family how to get it to show the door leaf size rather than the full width of the cavity framing??
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: wisedrawing
Revit doesn't have a "Cavity" Door in my OOTB Content Library.   Post the one you are working with here so we can see what you need to do.
FWIW:
If the door leaf width is controlled via a Parameter that is not an available Label in the Tag Family, you can open the Family and make that door leaf width parameter a Shared Parameter. Then you can load that door width Shared Parameter into the Tag Family.
If the door leaf is a nested family and is Shared, you could TAB-Select it to Tag it separately.
Nachricht 3 von 4
That can be easily added to a door family (if you need to tag) or a door schedule.
Nachricht 4 von 4
wisedrawing
brilliant work thanks, I have had that cavity door in for so long I forgot that I found it somewhere else bathbradley, with both your inputs here I just went back to the family, and into family types, and found the door width which had a formula that added multiplication of the door size and then some additional width - so I deleted that bit of type and its fixed - thanks heaps
