Area subtotal in a multilevel schedule
Message 1 of 12
Hello Im going a bit crazy trying to solve this issue.
Is there a way to get the subtotal area sum, in a schedule  classified by level and name?
Replies (11)
Message 2 of 12
PavelAnd
Hi @Anonymous . Check Sorting/Grouping.
Best regards, Pavel Plotitsyn.
Message 3 of 12
The problem with adding a footer is that it will itemize everysingle room in the project, i cant find a way to have the rooms sorted by level and grouped by name and at the same time get the subtotals of the area of the rooms in that level.
Message 4 of 12
PavelAnd
Make Footing only for one parameter which have the values NPT_P1 and so on. It will be easier to show if you send your file.
Message 5 of 12
That way i would have a table for the rooms on that specific level with its grand total, but not a multi level sorted table grouped by name with area subtotals  for each level.
Message 6 of 12
I'm not quite sure what you're trying to do - is it this?
Message 7 of 12
PavelAnd
Show your Sorting/Grouping.
Message 8 of 12
Here i uploaded an example file, i want to get the subtotals of the total area of the rooms of each level in the same table.
For example i want to have in the same table all the rooms or areas sorted by level and grouped by name and a subtotal of the area of all the rooms in that level.
Message 9 of 12
PavelAnd
That is it?
Message 10 of 12
Message 11 of 12
Thats exactly it! i had a brainfart and wasnt figuring it out!
thanks a lot
Message 12 of 12
robert.buchan.architect
Thanks guys, Works great in 'Murcan units too!
