Allign curtain wall to roof
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
819 Aufrufe, 8 Antworten
Goodmorning,
when I alling the wall to roof the two walls disalling.
What is the reason?
How can I fix the problem?
. rvt attached.
Thank's
8 ANTWORTEN 8
Nachricht 2 von 9
Alan.johnson1970
als Antwort auf: Anonymous
Im not 100% sure what you mean, but if it is aligning the curtain wall panels,
just unpin them and use align. Align them as required.
AJ.
Nachricht 3 von 9
RDAOU
@Anonymous
The way you set the curtain wall up is using "Maximum Distance" (0.755m) for the horizontal Mullions...in such case Revit will calculate automatically the offsets of the horizontal Grid line to fit in between the bottom and top constraints of the wall without exceeding 0.755m … considering the slanted roof on one side, the offsets on Wall 1 are different than those on wall 2 => misaligned
If you want them to align, use "Fixed Distance" =0.755 ...see below (click to enlarge)
Nachricht 4 von 9
als Antwort auf: RDAOU
@RDAOU  to have the roof"align" to roof I can only modifiìy perimeter as in pic 1?
With "attached top/base" say me "can't keep wall and target joint.
Nachricht 5 von 9
Do one or another. You either attach the base to floor and top to the roof, or detach all and edit profile.
Nachricht 6 von 9
als Antwort auf: ToanDN
@ToanDN  I ask the question in an other post
Nachricht 7 von 9
So your post 4 is just a statement and not a question?
Nachricht 8 von 9
@ToanDN  I'm wrong. i cancelled it now.
Nachricht 9 von 9
@ToanDN I write a new post for message 4.
