Area Plans
6 REPLIES 6
ZoiStathaki1
471 Views, 6 Replies
Area Plans
ZoiStathaki1
Could someone explain the advantages of why choosing Area Plans over Floor plans?
I would like to take measurements for client such as Gross Sellable Area, Gross Buildable Area, and Gross Floor Area. In principle I am thinking of Area Plans instead of Floor plans, because I can draw my boundary lines <area lines> where I would like to and after that create Area schedules too.
Area Plans
Tags (1)
Labels (1)
6 REPLIES 6
in reply to: ZoiStathaki1
Area plans are more flexible for areas because area boundary can be different from wall boundary + you can apply area rules.  You can also have multiple area schemes for different type of area plans and calculations.
You don't choose Area Plans over Floor Plans. You do both.
ZoiStathaki1
ZoiStathaki1
Understood.
@barthbradley could you elaborate a little bit more ? I will do Area Plans to take Area Measurements (which are requested from client), as I can have my area boundary lines independent to where the walls are. I.e: in the middle of the wall and so on... However, for Passive Fire safety drawings (which I also need to do) my thoughts are to use floor plans as I need to have both sections and plan views. This way, I can use rooms and room tags. If using Area Plans and Area elements, my issue is that unfortunately Areas elements are 2D only.
Understood.
ZoiStathaki1
ZoiStathaki1
@ToanDN, It seems that my client is asking me to do quite a number of things. One of them is to have opaque Area objects. I have the feeling that Area Plans are default set to transparent..?
Set the Area scheme location to Foreground.
Understood.
Your question is "I would like to take measurements for client such as Gross Sellable Area, Gross Buildable Area, and Gross Floor Area."  For those, you use three different Area schemes to create three different set of Area plans.
It does not mean you don't have floor plans.  You still have floor plans and the models normally.
Understood.
