are property lines in 2D?
3 REPLIES 3
PiPaPou
170 Views, 3 Replies
Are property lines 2D or 3D?
And may it be possible te show the property lines in 3D-view?
Is it possible to drape a property line over the terrain (toposurface)/ let the property line follow the surface?
Thank you in advance
3 REPLIES 3
vitorbortoncello
in reply to: PiPaPou
Only in 2D:
You can't drape it along surface, but if you want to visualize, maybe you can create a fake property region with subregion or subdivide.
You can use Railing to represent Property Lines in 3D. Railing will host to and follow the surface of Topos.
How to have a fence follow the terrain in Revit (youtube.com)
PiPaPou
in reply to: vitorbortoncello
Thanks for the suggestion.
Is it possible to export the Property lines?
Forma Design Contest
Technology Administrators
