Georeferencing IFC model and opening it in Arcgis ungeoreferenced
4 ANTWORTEN 4
Nachricht 1 von 5
saqouanealaa
354 Aufrufe, 4 Antworten
Hello guys , im working on my end of studies project ! i have georeferenced the ifc model in revit but when i export it and open it in ArcGIS Pro , it doens't stay in the georefrenced place . I need it to stay correct cause i'll have to convert it to citygml !
the model is georeferenced into EPSG: 25832 (Im not considering the elevation for the moment)
here is how it looks like in Arcgis PRO (it pops in the middle of the ocean ahahahaha) :
can anyone help please , the issue is somehow urgent !
If someone can help i'll really appreciate it !
thank you
4 ANTWORTEN 4
Nachricht 2 von 5
vitorbortoncello
als Antwort auf: saqouanealaa
Check the units typed in your survey point
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 5
saqouanealaa
als Antwort auf: vitorbortoncello
Hi @vitorbortoncello , I really appreciate your quick answer . Indeed the revit project units were set to meter before even georeferencing :
Nachricht 4 von 5
azad.Nanva
did you try these too?
Nachricht 5 von 5
saqouanealaa
als Antwort auf: azad.Nanva
Thank you for the answer , i actually have done these two but still the problem persist .
I really appreciate your help!
