Architectural+electrical settings
I am having hard times combining settings from different templates into one. I need to manipulate within a building and use the electrical settings at the same time. Setting a distribution system to a panel is only possible in the el. template.
Thank in advance for your recommendations.
Accepted solutions (3)
Try and transfer project standards from that template and include these settings:
s.borello
Not true at all... you will have full control within and Arch template to control electrical distribution systems, however you will need to create them or use transfer project standards.  Open the electrical template and check out the electrical settings & distribution systems.  You can use those numbers to add electrical distribution systems into your project... ensure you load MEP electrical equipment and devices with the proper electrical connectors.  Or... start off with an electrical template, then load all your Arch families in.  It will be quicker to just add Distribution systems to your Arch template.  Good luck.
