Hi fellas!
I've created a simple detail item family with horisontal lines (fill pattern). How do I keep these aligned with the family when the family's rotated?
Thanks in advance!
Gelöst! Gehe zur Lösung
If it's a drafting pattern you have options for aligning the pattern to the element.
@Anonymous wrote:If it's a drafting pattern you have options for aligning the pattern to the element.
I've tried changing that option, but I can't see any differences:
I think that only works for model elements - not simple filled regions. However, you can create a new model pattern in your family and that can be rotated.
