Cant hide Shared Reference Point Extension 2020
11 REPLIES 11
Message 1 of 12
Christopher_P
2456 Views, 11 Replies
Since downloading the update for the Shared Reference Point Extension Revit 2020 the x y z axis toggle arrows for the Survey Point and Project Base Point remain visible despite hiding these objects in Visibility Graphics. I have tried to unload this update but it still shows. This causes the Viewport widow to expand to include the toggle arrows which means viewports now overlap when placed on sheet. Can anyone help?
11 REPLIES 11
Message 2 of 12
you can try this go to properties > extents > tick all of them and adjust the lines. and see if helps. thanks
Message 3 of 12
No joy unfortunately. The x y z toggle arrows still show and automatically extend the viewport footprint on the sheet.
Message 4 of 12
it's a known issue in update 2020.2 > go to site and and un-check the internal origin. thanks
Message 5 of 12
in reply to: Christopher_P
Turn off Site > Internal Origin.
Message 6 of 12
Christopher_P
in reply to: ToanDN
Thank you! This is the solution. A new sneaky tick box added that I didn't notice.
Message 7 of 12
creardonYSFJ4
in reply to: ToanDN
Is there a way to hide the internal point on every view at once? Or do you need to individually hide on every view?
Message 8 of 12
you can create a view template turn off > internal point and apply to those views you don't want to see. thanks
Message 9 of 12
If you scroll up ToanDN sorted it.
Message 10 of 12
its a different question? thanks
Message 11 of 12
I shared a dyn file (from Autodesk) in a blog post. Run run it in dynamo player and it will turn off the Internal Origin icon in all views.
Steve Stafford
Message 12 of 12
in reply to: ToanDN
That's the answer-- thank you!! Turning off site/ internal origin worked for me.
Forma Design Contest
