Applying a pattern on a pannel
mahanmotamedi1991
mahanmotamedi1991
Hello Everyone,
I have made a custom pattern (DWG) using Autocad, and I want to make a family in Revit and apply this pattern on the panel's surface. I want to align the pattern's borders to the panel's borders and adjust the pattern with panel size. I tried to group the pattern, but I did not succeed. Any idea how I can do it?
Best,
Mahan
Mahan
RDAOU
@mahanmotamedi1991
When the panel resizes to grids what would happen to the pattern?
Option 1: An easy one is use cutout map in the material which you can resize to match the Panel Size (different panel sizes => Different Material)
Option 2: Treat the Panel with several Arrays of a face based nested voids
Option 3: An easier version of the above is to create the composition using added Grids + 2 types of panels (ie: 8 Fully perforated panels + 5 Solid ones)...ie: you will need 2 panels
  • 1 solid
  • 1 fully perforated
Option 4: Use Dynamo ... there are several methods one of which is applying an Image as a pattern https://www.youtube.com/watch?v=UgKwPuX04kQ
mahanmotamedi1991
Thank you very much for the response.
RDAOU
@mahanmotamedi1991
You are welcome...Revit file attached see if you can make use of the Panel or Material in it
That is how it would look with Option 1
And as per Option 3
