Apply Tag to multiple views at once
Message 1 of 9
Hi Friends, Do you know how to apply Tag to multiple views at once, or is there any plug-in to do that? Also, I would like to apply the keynote tag to multiple elements and views at once as well. I appreciate it if anyone has any idea to share. Thnaks
Replies (8)
Message 2 of 9
Same elements?  Then tag all in one view, select all tags, copy to clipboard, paste aligned to selected views, and select multiple views from list.
Message 3 of 9
GustavoUbriaco
There are no way, but with Dinamo you can create or download a routine to tag all elements you want in all views that you select
Gustavo Ubriaco Contreras
Message 4 of 9
Not the same elements. different elements in different views.
Message 5 of 9
GHASEM_ARIYANI
hello @Anonymous
this is a simple dynamo script.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
Message 6 of 9
chitt.kapadia
What if the element is in the linked model that requires tagging? (i.g. Rooms, area, spaces)
Message 7 of 9
Automatically Tag in EVERY View?
Wow! I can imagine the cleanup work that doing something like that would necessitate.  If Revit had a feature like that, I'd disable it, so that I couldn't accidently use it.
Message 8 of 9
chitt.kapadia
I understand how horrible that feature could be. Double tagging a lot of things. But you can always filter a list of view in dynamo. So the required views that need room tagging can be selected, and tag them from one of the linked model.
My current project has 7 models with over 250 views in total. Since, I am creating new views as project setup, I know that none of the views has tags in it. Doing "tag all rooms" from linked models per view takes time.
Message 9 of 9
gurump
Hi @GHASEM_ARIYANI Thanks for this. Know if this works for elements in linked models?
