Battle with crazy stairs
5 ANTWORTEN 5
Nachricht 1 von 6
384 Aufrufe, 5 Antworten
Hello ladies and gents!
I am battling with some stairs, tried different solutions to model the geometry.
Description:
1. They have to run from level 0 to level 1 (3450mm - with landing at this level) and continuing to level 2 (6900mm - same landing).
2. Riser = 150mm and Tread 230mm(narrow side) to 481mm (wide side).
3. The stairs need to have the same smooth continuity.
Question: Can these stairs be modelled in Revit?
Please set the attached ".dxf" geometry.
Thank you a lot!
All the best!
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
Nothing attached, but you can do a Sketch-Based Stairs, instead of Component Stair, to overcome some limitations.
Nachricht 3 von 6
Here, maybe you can see it now :leicht_lächelndes_Gesicht:
Nachricht 4 von 6
als Antwort auf: barthbradley
I have shared an image in a separate comment of the stairs
for some reason, I cannot upload .dxf or .3dm files :grinsendes_Gesicht_mit_lächelnden_Augen:
Nachricht 5 von 6
A Winder! Winders are easy.  It's a  Component Stair. Where are you having problems.
Nachricht 6 von 6
I'm trying to model them in revit by using different solutions, monolithic/non, and I cannot create these stair as one whole geometry running from level 0 to level 2 and afterwards creating those 2 landings. Do you know what should I try to do?
@barthbradley  appreciate it! :gefaltete_Hände:
