Message 1 of 9
08:35 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Okay, so I did see a very similar post regarding this issue however it was never resolved. I am hopeful someone has some insight as to what is going on. I have 2017 design suite and needed to have my cad reinstalled. IT thought it best to install the entire suite including revit. So, the images were not missing prior to the reinstall and now after IT uninstalled & reinstalled my suite the images are now missing. However, I do believe my library was installed because I can see the images in the directory and have visible appearance selections. Plus, it renders okay in Revit, its when I render to the clould is where the following dio box appears.. and yes I did add the path into my options rendering but that didn't fix the problem either Does anybody have any idea how to fix this issue, I need to get these renderings out the door but cant move forward!
