- Mute
- Permalink
- Report
I mean its not end of the world lagging but I would expected that upgrading to a new card would make the software run snappier.
My system specs are:
AMD Ryzen 5 2600X
32GB Ram on XMP Profile 2933 MHz
4k 144 Monitor running over DP at 4:4:4 4k
SSDs and GB wired networking with high polling 1000Hz mouse over USB
Interesting thing is the file is nothing just two walls and I still get stutters its the same for heavy files.
AMD overlay shows 100% micro stutter and frame gen times well over 250ms and sometimes 500-1000ms. It should be really less than 20ms in my opinion.
Also note that Revit viewport runs as expected if I RDP to this machine so whatever driver RDP is using to draw the display is working fine but direct draw to monitor is causing the problem I guess.
I have hardware acceleration turned on and draw visible elements only turned on and Revit is detecting the card and has all 3 green ticks, Direct X 11, Shader Model 5.0, GPU Memory 4GB.
I am running an Nvidia RTX 4060 at work and that card seems to work fine and smooth.
Any ideas how I can troubleshoot this problem?
