How do you change the dimension of a wall between two angled walls? In my drawing I annotated between the inside corners of two 45 degree walls. If you can see it, the dimension is 4'2 7/16" where the angled walls are in the top middle of the screen. It won't let me change the dimension if I click on either side of the wall like you can on perpendicular walls. I'm going off a handwritten drawing and he dimensioned from the inside corner of those angled walls.
Solved by L.Maas. Go to Solution.
I normally use the formulas option. For example if I want the wall to be 1300 mm instead of 1281 I move the wall to the right (or the left) and use a formula like this.
Let Revit do the math 😉
Louis
Please mention Revit version, especially when uploading Revit files.
Reason I think is because in order to use aligned anotation to anotate angled walls you are required to tab select the node at the end/intersection between two walls. When you select the wall later to change the dimension; Revit will not be able to identify/diferentiate to which wall this node belongs too as it is a comon point between two elements.
I personally prefer the @L.Maas (Aka. Louis) suggested... Just find it more practical than refplanes and more specific when it comes to which direction should the wall shift when the dimension is modified
