12:26 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
How do you change the dimension of a wall between two angled walls? In my drawing I annotated between the inside corners of two 45 degree walls. If you can see it, the dimension is 4'2 7/16" where the angled walls are in the top middle of the screen. It won't let me change the dimension if I click on either side of the wall like you can on perpendicular walls. I'm going off a handwritten drawing and he dimensioned from the inside corner of those angled walls.
Link copied
