Angled walls not joining
vbur8383
vbur8383
Hi All,
I know this is probably one of the most common issues, but my walls won't join cleanly. They're currently in a group, which I think may be having an impact . I've played around with wall joins and I've tried disallowing the joins and using join geometry, neither work (because of the angle). I have only used one phase for the building as I have seen this is a problem.
The bottom join was me attempting a "mitre joint" with the wall joins tool.
Any help would be much appreciated.
constantin.stroescu
I understood you have a group...try to work on Edit Group
https://www.youtube.com/watch?v=QpetQqpIFxA
Constantin Stroescu
Is Allow Join activated at Wall End?
vbur8383
Yes, I tried allowing and disallowing the join many times
Check their phasing. Maybe they are not in sync.
